CNKS
03-12-2006 18:16:27
Re: B maniac in reply to Rod (NH), 03-12-2006 14:50:23
Nothing to discard, as I have thought about and actually experienced most of what you say. Long story, bear with me. The booth was originally intended to keep overspray out of my 900 sq ft work area. The booth is 8 wide x 10 long x about 7 high. (The doors are 8' tall and protrude above the top of the booth, as I and not a carpenter, and did not build a frame that they fit inside, they close against the outside of the booth. The fans were sized to meet the 100 ft/min spec according to my approx 56 sq ft opening. Turns out I don't need anywhere near that much air to exhaust the fumes in a reasonable amount of time. Also I can leave my heat on as the fumes are contained in the booth, the "make-up air" the fans bring in does not lower the air temp too much so that I can't paint everything in the booth -- it doesn't hold much. The "doors" were to remain open and and be used as extensions to the booth along with frame work to attach plastic sheeting for when I paint the chassis of the tractor -- this is not needed since with the fans on I can paint that without contaminating everything-it doesn't take that long. In fact I had the doors hinged so that I could not close them, they remain opened to the outside along the sides of the booth to save space. When I first began to use the booth, I was painting only small cast/forged parts along with some stamped steel smaller parts that the "nibs" became visible on. They are, of course also on the cast but are not particularly noticeable because of the rough texture. Upon seeing the nibs on the relatively smooth small parts, I realized I had better filter the air. AND, yes I have seen those nibs on sheet metal previously, but the number seemed lower. So I cut openings, as stated below 4 16X20 inch in each door, rehinged the doors so I could close them, and put rubber stripping at the bottom, sides and top -- not a perfect seal, not as good as if the doors actually had a frame but much better than nothing at all. They are pretty well sealed. First I used the cheap furnace filters -- they were not effective. The more expensive ones seem to help, but still did not eliminate the problem. This past Friday, as an experiment, I painted the first large piece, the gas tank of my 460, which except for the bottom, is covered by the hood. Epoxy covered by MTK is enough for this piece, no 182 surfacer. Got a lot of nibs, thus all the questions. As mentioned, I have seen this before, the extent of which was not too bad. Previous tractors were painted in the 900 sq ft area, no exhaust fans, but I did turn on a regular fan to blow the fumes out of the building between coats, along with opening a door and window to get the stuff out. I don't believe I have painted anything without using that fan (which later I decided could spark and kill me with it's exposed wiring and all the fumes in the building -- thus the booth. So thus far I have not done any painting in a completely calm enviornment, I may try that on some small pieces tomorrow. I believe I run the fans low enough to keep dust from coming around the doors, but I will do the air test as you suggested. With the fans wide open, and the shop doors and windows closed, I can almost create a vacuum, and they DO pull dirt in under my shop doors. They also pull a heck of a lot of air in through the window I open slightly to get enough air in. By the time it gets to the booth, maybe 15 feet away, the movement is less, but I am moving air, the relatively small filter openings in the doors probably increase the velocity, but I "feel" no discernable movement in the booth -- but of course I can see the fumes move. Time will tell.
