omni paint not drying
David Maddux
03-12-2006 19:48:40
A friend painted some parts with the omni urethane, thinned as required, but did not use the hardner. This paint would not dry. He brought the pieces over to my shop to put under infrared heat, and after 24 hrs. it still was sticky to touch. Left hang in booth with heat off for 3 weeks and still stickey to touch. Does he have a bad batch of paint? Dave.
David Madddux
03-13-2006 04:35:51
 Re: omni paint not drying in reply to David Maddux, 03-12-2006 19:48:40
Thanks guys, I suspected this was the problem. I havn't used much of this product.
Rod (NH)
03-12-2006 20:22:33
Hi David,
Unlike the OMNI enamel, the use of a hardener in OMNI urethane is not optional. It is required for proper use of the product, as clearly stated on the can label mixing instructions and on the technical data sheet. It would appear that your friend simply didn't pay close enough attention to the manufacturer's written instructions. Sorry, but I think the only fix is removal and starting over.
third party image Rod
CNKS
03-12-2006 20:11:44
Acrylic urethane will not cure without hardener. He MUST use it. If he is afraid of isocyanates in the hardener, and prefers Omni then use Omni acrylic enamel. It will cure without hardener.
tommyw-5088
03-18-2006 05:57:00
 Re: omni paint not drying in reply to CNKS, 03-12-2006 20:11:44
they will not dry without hardner .this past winter i painted a deere grain drill with ppg polyurethane .at about 50 degrees it would not work right ,stayed sticky for several days . i knew better but went ahead annyway .im not real picky with implements normally just want to stop rust.
