How to strip/paint radiator
Daniel Dunmore
03-15-2006 06:37:47
Had my radiator checked for leaks. The shop repaired it, flushed it and...painted it glossy black. How should I strip this and paint it? Can I use a lye solution? Does painting it like the rest of the engine inhibit its cooling capability? Any special considerations for radiators in general?
rustyj14
03-15-2006 11:51:57
 Re: How to strip/paint radiator in reply to Daniel Dunmore, 03-15-2006 06:37:47
I was told years ago, when i worked in an auto body collision shop, that radiator shops painted the rads with a special concoction of black paint, to enhance the cooling process! I would leave it alone. after all, aren't most rads painted black, originally? I do think, if you paint it with enamel, you will have cooling problems! And, any enamel applied to it will be too heavy a paint coating for cooling to be effective!
CNKS
03-15-2006 09:47:14
Sodium hydroxide/oven cleaner (lye) might work, you will have better luck with chemical paint stripper. But, unless the black paint conflicts with the color of the tractor, I would leave it alone. I paint mine IH red after the usual cleaning and sanding. However, I do not usually paint the core, only the tanks. If they did paint the core black, my preference would be to leave it alone, as you aren't going to get all the paint off the fins anyway.
EX-pro
03-15-2006 07:47:20
Black is the best color for dissipating heat. I prefer flat black SEM trim paint. If you do repaint, don't get it on too thick
