Removing bubbles in decals
Vic
03-29-2002 19:01:10
Hello,
I just recently purchased a 49 M and there are some bubbles underneath the decals. Is there an easy way to remove them? Will applying heat like a hairdryer work?
JD
03-30-2002 17:50:54
 Re: Removing bubbles in decals in reply to Vic, 03-29-2002 19:01:10
If they are vinyl cut decals placing the tractor in the sun should do the trick.
JD
03-30-2002 17:50:00
Joe Appleton
03-29-2002 21:41:09
Vic, the sticker may melt, take a stick pin and pop the bubles then smear clear silicone over the hole and then shlack it with clear sealer. Works evertime
