Paint for farmall
RFOsgood
03-24-2006 18:05:09
I am restoring a farmall and need to get the correct paint codes and what kinds of paint and primers I should use. I am looking for the original red and white paint codes for a 1958 Farmall 240. I am also interested in finding out what color the dash or instrument panel was. The tractor was re painted and the dash is white now, however I found a sales flyer and the dash is black. If anyone knows what the dash should be please let me know.
I plan to use a epoxy primer, with Dupont centari paints, unless someone has better suggestions
ANY HELP WOULD BE GREATLY APPRICATED
Thanks Russ, Cape Neddick, Maine
sammy the RED
03-30-2006 20:37:12
 Re: Paint for farmall in reply to RFOsgood, 03-24-2006 18:05:09
IH-901 White
IH-2150 Red
doug bobk
03-29-2006 09:56:43
Theres some good informtion..is that the same red that is used on the farmall 140...if it is, i got a good answer.
Doug
Rfosgood
03-29-2006 11:12:51
 Re: Paint for farmall in reply to doug bobk, 03-29-2006 09:56:43
I think so
the tractor vet
03-25-2006 18:20:50
Well as much as i hate to say this but the john deere flat black does the best job on the dashs that we have found as for the paints myself i have always used the Case I H 2150 red and the cub cadet white it is not expencive and looks good .Primer well we use the case i h stuff andit has done well for use. But each to his owen .
CNKS
03-24-2006 19:50:43
I am not sure of the dash color, and I don't think the exact colors are available anymore. You might ask on the Farmall forum this site, or ask for Ken Updike on the Red Power Magazine Forum. I have a 46o with the same problem. I believe Ken said it was some shade of gray on the early models and "satin black" on the later ones. I think I am going to find some version of satin black, not saying the 240 is the same, although it was built in the same time frame.
Rod (NH)
03-24-2006 19:28:11
Hi Russ,
Not far away huh? I'm over here in Farmington, NH. CNKS will probably provide some input on the colors. I'll just throw in my two cents by saying I think epoxy primer is the best choice you could make, provided it is a two-part automotive epoxy and not a rattle can make-believe product. Centari is arguably also the best, especially if you are trying to avoid isos and use the Ultra 1K version of field mixes for it - that is, unless cost is no object. If you are very particular about color shades, buy only the minimum amount of color until you are satisfied with the result - no matter what any code indicates. Modern automotive paints do not always match the old tractor colors that well.
third party image Rod
