General Questions
Nathan S
03-27-2006 18:07:06
Is high temperature paint required for the head or block on an engine. I have a ford 861 gas. What color of primer should be used with orange/red paint. I can purchase red oxide or gray primers.
Thanks for your help
souNdguy
03-28-2006 12:06:30
 Re: General Questions in reply to Nathan S, 03-27-2006 18:07:06
CNKS is right on. On all my tractors, i merely painte dthe head / block with the same paint on the chassie and tin. Exhaust manifold is the only one that burns off.. and that's even using cheaper BPS ( alkyd ) paint..
Soundguy
CNKS
03-27-2006 19:34:03
The only place high temperature paint is needed is the exhaust manifold, if you want the paint to stay there -- On mine, I just let it burn off. You can use either primer, color makes no difference. Some like to match the color to the topcoat so that chips or scratches are less visible. Others like a contrasting color to make sure they get full coverage with the topcoat. I prefer epoxy (two part) primer. Your tractor dealer will not have it. It can be purchased from PPG, DuPont, etc. It adheres to the metal better and provides better adhesion to the topcoat.
