I rattlecanned my first tractor too.. Won't ever do that again.. lots cans of primer.. lotsa cans of 'tin'.. lotsa cans for cast... witht hat money you could buy a real setup. My next few tractors I painted with a very inexpensive setup.. an 80$ pancake compressor, a 15 gallon air tank, and a 14$ paint gun marked down to 9$ at the chinese store ( siphon type.. non hvlp ). I also used a 19$ air regulator and filter.. though a 9$ air reg by CH is available as well as 4$ disposable paint filters for hooking on the air line right at the gun. Takes a bit of patience for air to come up.. but is ok. I finally 'upgraded' to a 27gallon air comp with a built in air reg... still use the 9$ gun. The cheap gun is 'fine' for tractor painting.. just clean it well.. IE, add thinner to bowl, wipe clean.. add more thinner.. spray till mist is clear on a paper towel, wipe outside of bowl till clean, and wip nozzle down with thinner to keep air and needle clean... and that goes for any gun.. a 10$ one or a 150$ one.. clean is the only way to go. Sure.. you use about .5-1 qt thinner / naptha.. but it is worth it. Also.. metal prep work is worth 4x as much to the outcome of the tractors finish look than the amount of $$ you spend on the paint supplies, and home much $$ you have in paint equipment ( compressor / guns ). Soundguy
