second primer coat?
chuck130
04-03-2006 05:20:56
Primed my block, transmission and rear axle individually. Used Nason Ful-poxy. When I bolt the pieces together, and attach the 'add-ons' such as steering housing, inspection covers etc, I want to prime all these parts, as well as bolts/nuts - basically re-prime everything. What kind of prep do I need to do with the already primed surfaces? Also, surfaces that receive gaskets - should they be bare metal or is it OK to leave primed. Thankyou
CNKS
04-03-2006 06:01:55
 Re: second primer coat? in reply to chuck130, 04-03-2006 05:20:56
I haven't used DuPont products -- you need to go to their website and get the spec sheet for your product and follow those instructions. But, most epoxies also have a window during which they can be recoated without sanding. They also do not sand easily -- that means when you do sand, you will have places that go to bare metal, thus another coat needs to be applied. A scotchbrite pad is probably adequate for "sanding". Do not prime any machined surfaces, I mask them off or remove any overspray. Others may have different opinions on that.
souNdguy
04-04-2006 06:52:57
 Re: second primer coat? in reply to CNKS, 04-03-2006 06:01:55
Agree with CNKS.. no paint on machined gasket / mating surfaces!
Soundguy
