parts removal
tomturkey
04-03-2006 06:55:38
How much of what hangs on a tractor should you remove? Do I remove the brake/clutch pedals, hydraulic lines,starter, generator,distributor, radiator? Then hang and coat these items,then assemble and touch-up??? How did they do it in Racine in 1950?? thanks
CNKS
04-03-2006 16:56:54
 Re: parts removal in reply to tomturkey, 04-03-2006 06:55:38
Up to you, there are no rules. I remove everything that I cannot easily paint when mounted, which means almost all parts that bolt on. If you want paint on all sides of the parts you listed, they have to be removed. There won't be any paint on the chassis/engine either if you don't remove them. You will have to touch up the bolts with a brush when you reassemble. I believe most of the old tractors were more or less assembled when painted. But, the paint jobs weren't too good either.
