40 POUND PRESSURIZED ABRASIVE BLASTER
Paul In On
04-06-2006 20:50:06
Will this do good to take paint off? What size of compressor shold I use with it? It's on harbour freights but since they don't ship to Can will get it off of ebay.
CNKS
04-07-2006 05:30:31
 Re: 40 POUND PRESSURIZED ABRASIVE BLASTER in reply to Paul In On, 04-06-2006 20:50:06
It looks similar to the one I have, except I can get close to 100 lbs in mine, or more than one 80 lb bag of sand. The amount of air depends on tip size, and the bigger the tip the faster you can blast. I forget the size tip mine requires to do an acceptable job. My compressor will put out 24 cfm at 90 psi--and works ok, it is still slow. The smallest compressor you should even consider is about 15-17 cfm at 90 psi, unless you are only going to do very small parts. Compare that to the 300-600 or so cfm the professional blasters use -- that is a BIG difference. That one is a Chinese knockoff, the USA ones cost 2 or 3 times that amount, but are higher quality, partially because the nozzles/controls are better. They are not necessarily any faster.
