Coat coat sanding?
Andrew Betzner
04-18-2006 08:49:58
Ok after i apply three coats of color alowing them to flash inbetween coats, do i let it dry then sand it with 600grt then give it three more coats and repeat until i'm satisfied? Or do i just give it three coats and its done?
CNKS
04-18-2006 09:45:17
 Re: Coat coat sanding? in reply to Andrew Betzner, 04-18-2006 08:49:58
Don't sand unless you have defects you can't live with. If you do sand, you may be able to cover with one coat (I am in the process of trying that for the 1st time, as my paint has "cooties" in it that I have not yet found the source of). The more coats, the more chance for mistakes. And, eventually you will get the paint too thick.
