supplied air hoods
mace56
04-22-2006 09:42:08
Just wondering advantages of half mask with hood versus air supply to hood with cartridge mask.
Seems like supplied air half mask and hood would be good if you can remove hood and leave mask on when cleaning gun, refilling cup, moving parts, etc.
The Hobby Air stuff is not clear, when they use half mask does air hose supply go to both hood and mask?
SWI_Don
04-25-2006 20:28:38
 Re: supplied air hoods in reply to mace56, 04-22-2006 09:42:08
I have the Hobby Air half mask and the tevek painting hood. I haven't had a chance to use the combo for painting but have used the half mask with a sandblasting hood and it worked well. If you put the hose in the shade you get cool air blowing in your mask which makes sandblasting on a hot day a lot nicer.
CNKS
04-22-2006 14:28:07
I ordered my Hobby Air from www.autobodystore.com. I have a hood that was made to the specs of the owner of Autobodystore, Len Stuart, at least I think that's the way it is. It does not require a mask, the air comes in around the bottom of the hood. However I usually wear a cartridge mask under it for the reasons you mention. It is a tight fit. I have a paint booth and most of the fumes are exhausted, rather than getting out into my work area, but I can definitely still smell them. So, I feel safe removing the hood and refilling my gun wearing only the cartridge mask (I will notify you if I die). I try not to have to do that, and usually leave the building for a few minutes between coats. The other hood you refer to fits over the supplied air half mask, but you have to drag the hose all over the place. You can also get a full mask, I do not know if it will work if you wear glasses. You need a hood because iso's are attracted to moisture, ie your eyes.
Tom-Pa
04-26-2006 06:00:38
 Re: supplied air hoods in reply to CNKS, 04-22-2006 14:28:07
CNKS is correct about Iso's attraction to moisture (ie. your eyes.) You can use a half mask with supplied air, but be sure to wear an eye mask to protect your eyes. A half mask with cartridges are no good as far as Iso's are concerned. Supplied air is the only way to go with them.
