primer
Justin Squire
04-24-2006 11:49:26
I now realize that it is not the best idea to spray paint the tractor. I will most likely use a paint gun to paint the tractor. Is it ok to spray paint on the primer, though, because it won't be seen?
Brad_bb
05-03-2006 12:57:52
 Re: primer in reply to Justin Squire, 04-24-2006 11:49:26
Spray can primers are not nearly as good as two part primers like PPG DPLF Epoxy primer. It really seals the metal and seals out moisture. Must be applied to clean well prepped metal and not over rust.
CNKS
04-25-2006 07:55:40
If you use good paint, you need good primer. They work together. Also with spray can primer you run the risk of it not being compatible with the topcoat. Every time I try to shortcut something, things get messed up, for one reason or another.
