50 year old finish
mace56
04-30-2006 18:28:03
I know that sheet metal should be stripped bare. My 1951 Allis B valve cover has paint that seems solid as a rock. Has resisted repeated attempts at oven cleaner and wire brush on the grinder.
Not a critical appearance item. In your opinion, if it is on that good, and it does not bubble under my epoxy primer, then I can leave it? I have found traces of original finish in other hidden areas with same result, the stuff seems impervious to everything.
souNdguy
05-02-2006 12:31:29
 Re: 50 year old finish in reply to mace56, 04-30-2006 18:28:03
I'm pretty sure that electrolysis would lift that paint...
soundguy
mace56
05-01-2006 10:22:55
good point, it is pretty slick stuff. I will at least scuff it up. Interesting finding was that traces of oven cleaner will destroy Scotchbrite wheels. Back to good old sandpaper.
CNKS
04-30-2006 19:35:11
I strip everything, just because that is the way I do things. Your paint won't resist sandpaper, or a fiber brush on an electric drill. Or you can use chemical stripper. Can you just paint over it --- sure. Sand it first for adhesion.
