Mace, My answer to your question is yes. However, I don't know why you would want to bother for the cast. By applying surfacer within the epoxy time window you can avoid having to reapply epoxy at a later date if you cannot topcoat within that window. That's fine for the sheet steel where the surfacer, as intended, is going to be sanded anyway prior to topcoating. I don't see what you would gain by doing that on the cast. As with any cured product, the surfacer should be sanded prior to applying anything on top of it - even if done at a far later time. If you don't use the surfacer on the cast and (for whatever reason) go past the time window of the epoxy you should scuff with a Scotch-Brite hand pad and apply another coat of epoxy at such a time that you can apply the topcoat direct to the epoxy within the time window. Either way, you are looking at applying another product before the color and a sanding or scuffing operation. Application of the other product is just at different times; e.g. within the window for the surfacer and after the window for the second coat of epoxy. Sanding or scuffing should be done in either case. So there is no benefit to the surfacer unless, as CNKS says, you just like sanding and don't mind going to extremes in trying to make the cast as smooth as the sheet metal. I don't know why your jobber is trying to steer you away for epoxy. Perhaps because he sells more etch primer. I haven't bought any etch primer in years but suspect it may be cheaper that epoxy. In any event it has a time window, just like the epoxy does. And usually more restrictions on the use of it. Etch primers and surfacers go together almost as a requirement whereas epoxy can be topcoated directly without any additional priming. There are those that prefer an etch primer and those that prefer epoxy. For me, it's definitely epoxy. I wouldn't give you a plug nickel for any etch primer. If for some reason, I was going to etch-treat bare sheet metal, I'd use the separate, two-step chemical clean plus conversion coat method. That's a rather messy and time consuming process and I can see why it's probably not used to any extent in body shops where time is money and using an etch primer can mean greater profits. Especially since a surfacer is likely to be used regardless. Don't let recoating epoxy after the window has past be a key factor in any decision. I think people make too much of that. It's not as bad as it sounds. Much of my work consists of sandblasting as an initial step. I prefer to apply epoxy the same day for the best protection. As CNKS indicates, Picklex 20 teatment is another option for interim protection and I have used that too when it fits my schedule better - but I still prefer the direct epoxy right after blast. My effort may spread over several days because I also do several smaller parts at once before any color. I sometimes miss the window since I paint outside and the weather doesn't always cooperate with my plans, despite weather forecasts. I just scuff when I am ready to apply the topcoat, shoot another coat of epoxy and then proceed directly to either the color or surfacer (if needed) depending on whether the part is sheet metal or cast. For me, it's not that big of a deal to do that. Pro body shop materials, procedures and equipment are not always the best choices for a DIY working on a tractor. Big, big difference between a DIY doing a tractor on his own time (and budget) and a pro shop doing collision repair on a car or truck for profit. There are some commonalities to be sure, but they are two quite different worlds. Rod
