JB Weld as body putty
Marvin Gill
05-09-2006 09:58:00
Hello. I have a few small rust holes in the fenders of my "64 Caddy and I used something similar to JB Weld to fill them in and then sanded it smooth. It really came out nice. I was just wondering if anyone else has tried this and what became of it. Thanks--Marvin
soundguy
05-10-2006 07:35:11
 Re: JB Weld as body putty in reply to Marvin Gill, 05-09-2006 09:58:00
As CNKs said.. I've used jb weld as a filler for areas i didn't feel bondo would hold up.
Also.. On areas where it was not practical to weld up holes in sheet metal.. like small pin holes covering a small section of metal that was otherwise sturctually intact and not pitted, I have used jbweld, smeared on a piece of aluminum flashing, and then applied to the back of that sheet metal, thus extruding the jbweld thru the holes. Once cured.. just sand down the heads of the extrusion, and you have a decent pinhole repair.. that won't push out like bondo will.
Soundguy
mace56
05-09-2006 18:09:50
I notice a lot of the pitted sheet metal is right around bolts. (See Rod NH fender.) I wonder if normal body fillers would just crack when the bolt is tightened? Perhaps if you are careful to only fill the pits and sand it back to expose the high points?
CNKS
05-09-2006 17:00:21
I haven't used it to fill holes. But I will typically use it to fill hard to fix dents, and places where I don't consider durable enough for bondo -- example the transmission cover on my Farmall Super H, that was damaged by battery acid. I usually put a thin layer of bondo over it, as JB Weld is hard to sand smooth. No problems that I am aware of.
Jak
05-09-2006 11:25:23
I have used JB Weld several times in stress points that I thought bondo would crack on with success.
robinap
05-11-2006 21:39:25
 Re: JB Weld as body putty in reply to Jak, 05-09-2006 11:25:23
I use jb weld to restore steering wheels w/succes
