I read your link. Thanks. It seems to be a survey of user hazard awareness rather than any specific agency recommendation. I didn't find any specific conclusion except that more awareness efforts are recommended. I think all references were to professional spray booths and did notice a passing reference to supplied air in a booth. Also passing references to filters but nothing specific. As far as 3M goes, I have noticed they recently (in the last couple of years I think) in their respirator selection guide are now recommending one of their cartridges for typical isocyanate compounds using a negative pressure, air purifying respirator - but only under very specific conditions: 1) the actual airborne concentration must be known, 2) that the concentration can be no more than 10 times the standard permissible exposure level of 0.005 ppm, 3) that N95 prefilters must be used and 4) a cartridge change schedule as promulgated by the OSHA be implemented. Of course proper fit testing is presumed which would preclude anyone with facial hair from using such a respirator. The bottom of page 6 is particularly relevant. This is, of course, from the maker of the filters who obviously has a vested interest in sales. They certainly do not "certify" any cartridge safe for isos and as far as I know, no one does. In any event, such provisions are not really in the realm of the DIY to even begin to properly evaluate. Pro body shops usually have a professional paint spray booth that has had a complete industrial hygiene survey done by an independent agency who confirms proper airflow and measures airborne concentration levels in the painters breathing zone in order to establish baseline exposure levels - a much different situation. OSHA has a lot of linked material relative to isocyanates. They have a lot of regulations applicable to body shops that is interesting but not really reasonable to implement for most DIY operations. NIOSH is one of the key agencies who develop and recommend permissible exposure levels although I don't believe they have any actual regulatory authority. HDI is one of the several isocyanate compounds used in paint hardeners and activators. From what I have seen and read about others, HDI is pretty much typical of them all. They seem to be treated as a family of hazardous compounds. NIOSH has published this on HDI. They recommend supplied air even when exposures are less than the generally accepted one (0.005 ppm). More from NIOSH here. They clearly recommend supplied air even inside a well operating professional booth. Similarly on HDI, the New Jersey Department of Public Health has this to say. Still more from NIOSH here with the following excerpted text: Whenever there is potential for exposure to diisocyanates, even concentrations below the NIOSH REL, NIOSH recommends that employees be supplied with supplied-air respiratory protection. (Negative pressure air-purifying respirators are not recommended since diisocyanates have poor odor warning properties.) Also, there should be a respiratory protection program.
The California Department of Health Services has this to say. The Saskatchewan Department of Labor has this to say. PPG's official position is here. DuPont's is similar and explicit in their applicable MSDS. I personally think the evidence for supplied air when using iso-containing materials is overwhelming despite some pro painter's insistence to the contrary. I also think that it may be even more important for the DIY than for the pro painter who works in a booth. There are more unknowns and variables with a DIY, even when he works outside. Pro painter's opinions are important and I respect them. However, I will always give more weight to the independent agencies who have the actual responsibility for recommending safe work practices for all. I'll certainly agree that the paint manufacturer's are generally conservative in their recommendations. They have every reason to be. What gets me is the whole thing is so easy to correct. No DIY has to use hardeners when painting his tractor. It's entirely optional. There are alternative paints that do not require them. Inferior you say? Sure they are. But they were perfectly satisfactory before isos were ever developed and can be put to good use today. Indeed, they are as good, sometimes better than the original OEM paint that was used on most vintage tractors. If someone wants to get better performance from paint, they can evaluate the health risks for themselves as well as the cost of the excellent protection provided by supplied air. Arguments over iso exposure levels are academic anyway. It's simply too easy just to go with supplied air and have little further concern about the whole matter. I learned that the hard way for myself a long time ago. Best money I ever spent. But to each his own.
