Steam clean vs. pressure wash
Dave
04-05-2002 02:25:41
In the near future I am going to start prep. for a paint job on a tractor.Typical of any old one,grease,dirt,crud,flaking paint,etc. Have been wondering if I should pay somebody to,or maybe rent a steamjenny. I have a decent pressure washer and used it to cleanup my dads tractors last year.But I wasn't getting them ready for paint either,they would have needed more scraping and cleaning.Guess we've all seen those "quickie" paint jobs,with dirt,grease under the paint.I want a decent job,dosen't need to be 100% perfect,but still a good one.Any input guys?
JMS/MN
04-14-2002 22:48:25
 Re: Steam clean vs. pressure wash in reply to Dave, 04-05-2002 02:25:41
Steamcleaning can't be beat, but lacking that, run hot water through your pressure washer- it is better than cold for getting thick grease off.
Jeremy
04-07-2002 20:09:57
Castrol Super Clean does a respectable job at cleaning up grease and whatnot. Used it on the engine in my Nissan and the engine came out spotless after using the Super Clean and a garden hose (no pressure washer.)
Keith
04-05-2002 03:34:42
Dave Have used both on tractors and steam / HP works the best. The one I use is live steam at 1000 psi. But be carefull of tight spots it all comes back in your face! I wear a sheild. HP alone is ok but will still have some film left on the rig. The other thing is to be carefull of rubber parts, tires,wires, etc it will shred them in a flash. Good luck Be safe! klj
DAVE S
04-06-2002 01:39:29
 Re: Re: Steam clean vs. pressure wash in reply to Keith, 04-05-2002 03:34:42
I use mean green or simple green full strenth,then my preasure washer.It did a good job but, you may have to do the engine twice over for thick caked on grease.
Dave
04-06-2002 04:11:35
 Re: Re: Re: Steam clean vs. pressure wash in reply to DAVE S, 04-06-2002 01:39:29
I went to our local Rent-it-center,they used to have a hot-high pressure washer,but never had it replaced after it broke.I am going to check a couple of other sources.I still may scrape tractor down as good as possible,slather it up with degreaser-mean green,or similiar product,and proceed to get wet.
Cliff Neubauer
04-06-2002 09:40:18
 Re: Re: Re: Re: Steam clean vs. pressure wash in reply to Dave, 04-06-2002 04:11:35
I've had good luck spraying tractors down with diesel fuel, keep the wet for a day or two then power wash it. You will still need a degreaser for the final wash but the diesel will soften up the thick stuff and is much cheaper than commercial degreasers.
Dave
04-06-2002 04:06:32
