Johnny, If most of your parts are blasted to bright metal, you have the very best foundation for any coating system. In my opinion that is deserving of the very best bare metal primer - an epoxy. It doesn't have to be an expensive premium version but it should be an automotive, two part epoxy. In some cases, if you don't have to do any heavy sanding or other type of bodywork, you can skip the surfacer altogether and topcoat directly to the epoxy. Although it's not a filler and is basically non-sanding (although it can be sanded) it will fill a typical blast profile quite nicely with two coats. Therefore a surfacer product can perhaps be eliminated. Of course you probably would not be using a surfacer on the cast parts anyway. I think you have indicated previously that you have fresh air breathing equipment? Assuming you do, then I would loose the lacquer-based primers/surfacers altogether. Either keep 'em around as a monument to times past or give 'em to someone who doesn't have the proper breathing equipment to safely use better stuff. Get some 2K, urethane-based surfacer to go with the epoxy for when you need to fill sandscratches, etc. Like the epoxy, it doesn't have to be an expensive item from a premium line. Those two basic products will provide you an excellent undercoat system for about any type of topcoat you wish to apply. I have never used Martin Senour products and don't know enough to talk intelligently about them. I do know that they have more than one "quality" (and price) line of automotive paints, just like DuPont, PPG and others. I am sure they have similar products also, like epoxy and 2K surfacers. I know that their stuff has a following around my area because the local NAPA store seems to be doing well selling it - even with both DuPont and PPG competition within five or six miles. We could argue all day about whether you should go with a premium product or an economy product. Only you can judge how much you want to spend for what may be unimportant (to you) marginal differences between premium and economy qualities. The cost difference can easily be two or three times between the two. The bottom line is a two-part epoxy and a 2K surfacer in any line of automotive paints from a recognized manufacturer should serve you very well indeed. As CNKS indicates, you need to be aware of epoxy recoat time windows to obtain the best performance. That will be spelled out in the appropriate tech sheet. If you don't have a link to the MS website that has both technical data sheets and MSDS sheets for all their products, post back. Rod
