CNKS
05-23-2006 19:55:16
Re: Spraying topcoat around corners and more dummy in reply to mace56, 05-23-2006 18:40:11
I'll try to answer the last part first. you must get all that stripper off, out of every nook and crannie or it will lift the paint. By the time I get to that stage the wheels are off the tractor, thus it is immobile. Also I can't use a pressure washer or even a hose (can use hose with care) inside my building because I did not put a drain or have the floor sloped when I had my building put up. So I use soap and water, 409, etc with a lot of rags and rinsing, followed by liberal repeated applications of wax and grease remover. Have not had a problem, yet. As to painting, I assume you are going to use epoxy first. That will give you some practice. You will get some overspray unless you mask things off. I don't. I do get some fading in some areas that I assume is dieback, but I don't believe it is from the overspray, I think it is from "double" spraying, that is accidentally or on purpose overlapping on a previously sprayed area that has not flashed. You will see the overspray immediately, the dieback may not show for weeks or months. You can spray the underside first if you want to. Unless you lay on your back under the tractor the overspray will not be noticable. The underside of my tractors look pretty good condsidering I have to spray at an angle. A pressure pot would be better though. I really don't have a solution for the rest of the tractor, except to avoid double coating as much as possible. Start at the front or back and work around the whole tractor. I use 3 coats. Be particularly careful with the last coat, as that one will cover some of the mistakes you make, and if you don't mess it up you will have a decent gloss. However, although cast is rough and reflects light differently, it will not show overspray as much as the sheet metal will, but it is still there and it will affect your gloss. In my opinion, the dieback caused by overlap on the irregular surface is the biggest problem.
