Parts washer... O.K. to use kerosene in it?
Jim
10-16-2001 07:42:07
I have a 20 gal. parts washer which is not used that frequently. The "parts washer fluid" which is sold for this purpose seems to evaporate more than I like. Question: Can I use standard kerosene in it without the pump blowing things sky high? I belive the special parts-washer fluid is somewhat flamable... Have any of you tried kerosene? Thanks for taking the time to respond. Jim
Franz
10-16-2001 22:58:34
 Re: parts washer... O.K. to use kerosene in it? in reply to Jim, 10-16-2001 07:42:07
You can score a deal on mineral spirits paint thinner when it's on sale, and it works out cheaper than kerosene. It also cuts grease better. I learned about it from a transmission rebuilder who runs mineral spirits in a commercial dishwasher to clean tranny parts.
If your pump isn't right on the bottom of the tank, the heavy crud will settle out, and you get much better life out of the solvent.
Evaporation is easily controlled by just keeping the tank covered.
Denny
10-16-2001 12:26:40
I built My own parts washer, 20 gal. well pressure tank and a steel tub made from 16 ga. steel welded to the top. I bought a replacement washer submirsible pump and I run 5 gal. kero and 1 gal. Gunk in it. Works fine. I also use an in-line carb. gas filter to filter out crud from the washer solvent. No sense of putting all the crud & grit Your trying to get rid of back on the clean parts.
