My gun is a 9$ unit from harbor freight.. Syphon gun.. aluminum cup..Similar to the 10-14$ units you see at walmart o and other cheap tool stores. Close one eye, and stand 20' back and it almost looks like a binks.. In any case.. -MY- gun said to set are between 25 and 45 psi I generall pain around 38 psi to 40 psi. I mix my paint up per the can, and then go to test painting.. once the paint starts syphoning. I check my pressure gaugge to see that I am in my range while holding a steady spray, and then I adjust my nozzle pattern, and then lastly, air.. Once you adjust air.. you can probably 'leave' it, as long as you are using the same paint you normally use.. and reduce tot he same viscosity.. otherwise you may have to tweak the air a bit each time. Once you have the spray coming out good.. do some practice if this is your first time. Learn how to go from spray to air for vertain thing.. Make a few mistakes intentionally on your test spray.. see exactly what it takes to get a run on a vertical surface.. or a slump.. etc. Practice with painting a slight run out.. or blowing a slight run out. Find out what overspray does to a previously sprayed surface... Learn the environment... 0 wind is best.. or if there is some wing.. try to not paint into the wind.. humidity is an issue.. the paint you use and the temp and humidity will all be a factor. Same with your reducer.. etc. Buy compatible materials.. whether the cheap stuff.. or the spendy stuff... And remember.. surface prep is 85% or more of what the eventual outlook will look like.. not the paint.. or the gun.. technique , materials, environment are the rest of the equation.. I'm just a hobby 'hack' painter.. but if you practice.. a 10$ paint gun and small compressor and lots patience and more sanding that you ever wanted to do...will turn out a few parade ready tractors.. and deffinately plenty of workers.. Soundguy
