FWIW.
steve from mo -
06-12-2006 10:33:36
Bondo doesn't stick to rust very well or very long. You need to cut away all the bad parts and sand to shiny metal before you weld new tin into place, then seal both sides. Front with bondo, back with primer/undercoat.
With half-cured bondo you can use something like a cheese grater to do the rough countour. Then apply another coat. After a couple rounds, you can start to sand it smooth and use spot putty to fill any holes in the bondo. If you sand too deep and get a concave surface, you can put more bondo on.
