V is for Victory
souNdguy
06-14-2006 17:41:50
I got home from work and went out and tackled my batwing again. Had enough oil and grease on it that it could have been a KFC franchise.
Keep in mind that I have washed and pressure washed this thing on 2 other days.
This am before work I used a can of engine degreaser and sprayed the remaining heavy parts.. which was pretty much pin and bushing couplings. When i got home, i pressure washed using simple green. Then i sprayed it down with purple stuff and while that set I mixed up a bucket of plain old soap and water, and got the long scrub brush out and hit the entire machine.. To my dismay.. a few slicks still survived.
Another pressure wash with attention tot he proplem areas, and used simple green as a aid... then another scrub brushing with a little simple green in the water. This finally did it... no sheens.. no slicks... It dried to a nice non oily faded paint... probably hasn't been like that in 5 years. After it was clean I say a few hinge 'stops' that were beat up as well as a front brush guard bracket that was nearly broke so i burnt a few rods to correct those problems.
Now all I need is a dry day, and an afternoon off to hit it with some rust control primer.
( i'm so tired of washing and scrubbing... this was easilly the dirtiest piece of equipment I've ever worked on... )
Soundguy
jubilee johnny
06-15-2006 12:37:05
 Re: V is for Victory in reply to souNdguy, 06-14-2006 17:41:50
Good luck, It is always rewarding and worth the effort to spray the paint when all that prep work has been done.
jub////n//
06-16-2006 05:12:27
 Re: V is for Victory in reply to jubilee johnny, 06-15-2006 12:37:05
lye works great..so does oven cleaner
CNKS
06-16-2006 06:04:39
 Re: V is for Victory in reply to jub////n//, 06-16-2006 05:12:27
Oven cleaner is lye, at least the stronger versions -- NaOH.
souNdguy
06-15-2006 20:14:49
I've got tomorrow morning off, and hope to get the primer on. And perhaps saturday am for the paint?
Soundguy
DAN9-Midwest
06-14-2006 19:41:08
Have you decided on the type of paint? I know you spoke of somthing from TSC but also thought you mentioned acrylic enamel. How much paint do you think it will take?
souNdguy
06-15-2006 04:52:37
 Re: V is for Victory in reply to DAN9-Midwest, 06-14-2006 19:41:08
Deffinately using the BPS paint from TSC. I'm thinking of about 5 quarts paint...
Soundguy
n2rudr
06-14-2006 17:59:58
What type of primer are you going to use? Maybe you can post some pictures of the progress
souNdguy
06-14-2006 18:11:47
 Re: V is for Victory in reply to n2rudr, 06-14-2006 17:59:58
It's a valspar primer, grey, rust control ( etching? ).
I've already primed and painted the underside of the decks, and the primer went on nice.. took paint good. Bottom looks like a million bucks... figures that no one will ever see it. If the top side of the deck turns out near as good, I'll be happy.
I already got my new decals and am now just waiting for time off work and weather..
Soundguy
Soundguy
