What primer to use??
D dude
04-08-2002 08:25:45
I am currently painting a 450 farmall. What color primer should I use?? When I sanded the tractor down I noticed it looked like it had a red primer. Should I go back with this color?? Also will using a white or black primer change the shade of the paint?? Thanks in advance D dude
Dan
04-15-2002 20:46:50
 Re: What primer to use?? in reply to D dude, 04-08-2002 08:25:45
use IH gray primer if you are using IH#2150 red paint. If you use the IH red primer the paint will turn orange after a while
Dan
04-15-2002 20:44:33
D dude
04-09-2002 08:21:20
Thanks Everyone for all your help it is greatly appreciated. Thanks again D dude
ron schuster
04-09-2002 18:17:14
 Re: Re: What primer to use?? in reply to D dude, 04-09-2002 08:21:20
I use an industrial epoxy primer that I get from Mautz paints does very good job I use the gray when it is dry I use a scotch brite and go over it very lite just to knock off any roughness.
ron schuster
04-09-2002 18:16:02
Kevin
04-08-2002 19:37:19
Dude..... ..... . do what IH said to do but sand with 600 wet.Red is a dark color and will show sanding swirls on the top coat.Good luck
Kevin
04-08-2002 19:36:25
IHman
04-08-2002 18:16:34
use an epoxy 2 part primer. It not only seals the surface from previous paint bleed through, it will fill and give you a smooth surface to apply finish paint too. It sands hard because it is hard. Sand with some 400 wet paper and you'll have a great surface to paint onto providing you preped the metal good.
sammy the RED
04-08-2002 16:47:31
I use Red Oxide primer from Case/IH dealer. It is a good primer.
What brand of paint are you useing ?
Dave_Id
04-08-2002 12:26:58
Use the primer product that is recommended for the type finish paint you are using.
