CNKS
06-25-2006 09:20:44
Re: 1st Time Painting Advice? in reply to Tony (A2, MI), 06-25-2006 07:41:02
Epoxy primer on everything, sandable laquer primer surfacer over the epoxy on the sheet metal, this will give you a smooth finish. Then topcoat with acrylic enamel. Use PPG, DuPont, Sherwin Williams, etc. The acrylic enamel will give you fade resistance. PPG numbers are MP 170 epoxy, MP 175 catalylst (no iso's), MP 181 primer surfacer, MAE acrylic enamel. If you wish you can use Case IH 2150 red acrylic modified alkyd enamel, provided your tractor is past, I believe Nov 1936. if it is gray someone else can give you the code. If you want a perfect job strip all old paint and rust. Others will probably recommend paint from TSC or somewhere. The difference in cost in the tractor store paint and acrylic enamel, put in perspective, is about one tank of gas for your pickup. Including the better primers, maybe 3 or 4 tanks of gas. The 2150 I mentioned is technically the wrong color, but is close. The PPG/Dupont numbers for IH 50 for 1936-1949 tractors is 70019/7410. If you decide to have 2150 equivalent mixed the codes are PPG 71310/DuPont 96766. You need to read every post on this forum, as it is more complex than the explanation I have given.
