CN, I wouldn't push the flash time too hard or you will have trouble with the melting in of overspray. How long you can safely go beyond the stated 10 min (@70°F) is not defined. I don't think I'd want to push it a lot - but that's only a guess. That's for the overspray issue where you are doing a partial recoat or coming back to a point where you started earlier with the same coat. On the other hand, if you are talking about a complete reshoot where you are reshooting the entire part at a later time, I think it's a different case. In that instance, the concern is not the blending or melting in of overspray but rather the quality of chemical bonding of the new coat to the previous one(s). In the case of MTK which must be catalyzed, there is no concern with lifting after drying and the matter becomes one of bonding. MTK can be cleared up to one week per the MC161 tech sheet. I have never let it go that long and prefer to clear as soon as possible after the stated 4-6 hrs (MTK tech sheet). In clearing over decals I have deferred the clearing for two days - no scuffing. I'll assume that bonding of clear is essentially the same as bonding of more color (they use the same hardeners) and guess that you could safely recoat up to one week without scuffing. I once had to recoat MTK color because of a disaster (long story) during the second coat. I let it dry overnight, scuffed with Scotch-Brite and reshot two coats over the whole part. No problem. The reason I scuffed was because the part was relatively small and it was easy to do - an extra precaution and likely unnecessary in that time period. I don't think there is a specific answer to your question and it depends greatly on the exact product and hardener involved. For example, the maximum time for clearing of hardened MAE is only 24 hours, not one week like the MTK. If I were to recoat hardened MAE, I'd do it within the 24 hours or plan on scuffing it. When in doubt, be conservative if possible. Rod
