case IH primer
super red
07-17-2006 20:03:08
I was wondering how soon could you paint after priming with case IH primer ? or would I be better off with the epoxy primer for faster drying so I could paint the same day.
sammy the RED
07-28-2006 23:27:34
 Re: case IH primer in reply to super red, 07-17-2006 20:03:08
Most of the time, I wait 24 hours to paint after being primed w/Case-IH primer.
GordoSD
07-20-2006 10:47:25
I used the IH primer, and their reducer once. It tokk 10 days for that to harden up enough that I could sand it! Will never use it again.
Gordo
unioncreek
07-18-2006 12:34:52
I've use the Case/IH primer and painted over it as soon as it dried, about 15 minutes. I've also use an epoxy and then Case/IH paint. Both primers worked good, but depending on what quality of paint job you want depends on how much you want to spend on primer.
Bobg
