Hi, Wow, what a bummer with a great paint. Here's my thoughts: It appears to me that your jobber messed up. I know they can't guarantee a perfect color match with an original color. But...they ought to be able to mix two different cans the same. Unless you've done an awful lot of business with them I doubt they are going to be sympathetic to your problem - at least not enough to actually do something about it. Like eat a gallon of Concept. I hope you still have the first can available. I'd strip the labels off both cans. Underneath the labels ought to be the actual formula used that shows each mixing tint and the amount used in the mix. It should look like this. Compare not only the color code number but also the number and quantity of each mixing tint. If there's a discrepancy in the numbers, then I think that is pretty good proof that a jobber mistake was made and you ought to confront the jobber with it and request that he make the situation right at no cost to you. If there is no obvious discrepancy in the numbers, all bets are off. I still think it's a jobber error though. There may have been two different people who made the mixes who have different experience and different levels of care in doing their jobs. If the mixing tints are not kept stirred well at the jobbers (and stirred shortly before each mix), then all kinds of weird shades can be developed. If that's the case, then I don't think your chances are good. You can try prevailing on the jobber's desire to please the customer (you) but you may not get anywhere. If you don't, then I would definitely take any future business elsewhere, even if you have to go out of your way to do so. Retinting? You'd have to have the tints available and it would be a trial and error process. I doubt it would be worth it even if you have the tints - which you don't. And I doubt your jobber is going to want to spend any time at all messing around that way. However, if there is a mix discrepancy as noted above, then such a retinting might be possible. I don't know. I've never done mixes myself. Good luck, Rod
