clear coat
j peters
08-03-2006 09:38:20
just finished painting my farmall 200. this one i want to clear, i painted the tractor with nasson acrilic enamal, what should i use to clear and is there any thing i need to do to before i spray? thanks
Rod (NH)
08-03-2006 18:11:14
 Re: clear coat in reply to j peters, 08-03-2006 09:38:20
Hi,
I agree with B---. The product tech sheets should have been your first stop, even before you purchased any paint. The NASON ones are available from DuPont on-line here.
third party image Rod
B-maniac
08-03-2006 17:20:07
First of all,did you use catylist in the paint? Does Nason have an acrylic enamel clear with catylist for use over that paint? Assuming the answers are yes,do you have access to the tech. data sheets for proper use of the system? You probably don't.I say that because any paints that I know of call for a wet on wet when you are clear coating. That's what ties the two together so the clear doesn't de-laminate from the color. It is very risky to sand your color after dry and apply clear. In metallics it will create a real mess.In solid colors it may work a little better but the smart thing to do would be to sand the surface,apply one coat of color and then,after it has flashed off for an hour(or what ever the directions say)apply the clear. If you sand on dry red paint,if you look real close you will see that that it will look orange where the grit of the paper makes small scratches.Red paint darkens as it drys and for some reason the underneath always stays a little more orange.You don't want to clear over that or it will be there forever.You won't see it unless you look close but it's there.Depends on how fussy you are....IF the paint and clear you are using ISN'T catylized,then don't bother with the clear,it won't help. If you want the wet look on uncatylized acrylic enamel,use the buffer once a year. You may want someone experienced in this to do it for you.Auto detailers do it on cars every day,check with them. Good Luck however you go.
