WD hydralic pump
Buddy in A
08-14-2006 07:57:55
Where is the hydralic pump located on a WD. What drives it? My hydralic just quit working...what do you suspect is the most likely cause?
JMS/MN
08-14-2006 11:47:42
 Re: WD hydralic pump in reply to Buddy in A, 08-14-2006 07:57:55
Likely cause is operator error. Pump is located on the right side, to the rear of the belt pulley/pulley hole. Hydraulic lever at the steering wheel is connected to it. Your message tells me you do not have an operator manual. Buy one. Do not assume the pump is bad simply because the 'hydraulic doesn't work'. Diagnose problems in a logical, orderly manner- usually ends up being a simple problem that you can fix yourself. Replacing major components, especially when you cannot identify them, is not the way to tackle the problem.
