Case Paint
Don656
08-14-2006 15:12:59
OK, I bought Power Red and Desert Sunset from the local Case-IH dealer. Now, the questions is what kind of hardener to use and where to get it? Also, what would be a good primer to use with these paints?
Thanks,
Don
B-maniac
08-14-2006 19:20:51
 Re: Case Paint in reply to Don656, 08-14-2006 15:12:59
Instead of playing "chemist" with expensive paint,why not request a technical data sheet "directions" for this paint from your supplier.If they say there is no such thing,then get a refund on the paint and buy a different brand that does.You can't just go buying different components from different manufacturers and expect some kind of predictable result.Stick with a proven "system". Don't set yourself up for failure from the git go. Going "generic" is a crap shoot at best! Good Luck.
CNKS
08-14-2006 17:12:24
Someone else can recommend hardener. Case-IH does sell it, most counter people don't even know they can get it. But, with hardener, you need a supplied air breathing system. Primer is also sold by Case-IH. There are better primers out there. There is a lot of discussion about that on the following pages of this forum.
