Painting rims with the tires still mounted???? A
Bob in Buffalo
08-17-2006 14:57:08
HI, Repainting a JD R and need to blast and paint the rims/hubs. Anyone have any tricks on keeping the paint off of the tires, except for the obvious task of masking them completely off? I have made the mistake once of getting paint on a tractor tire..... and never again!!!
I'd appreciate any tricks you may have!
Thanks
Tim(Indiana)
08-30-2006 15:41:15
 Re: Painting rims with the tires still mounted???? in reply to Bob in Buffalo, 08-17-2006 14:57:08
I have used clear plastic sheeting. I cut a piece to cover the entire rim & tire, then mark diameter of rim. Cut hole in sheeting about 1/2 - 1 inch inside mark. I then stretch plastic and work between rim and tire.
This works better if you can break the tire beads loose from the rim (without removing tire). Hope this helps, Tim
Tim(Indiana)
08-30-2006 15:38:41
Bob in Buffalo
08-24-2006 04:18:32
Thanks for the advice. I will be painting today and see how it goes!
Thanks again, Bob
jubilee johnny
08-24-2006 08:29:17
 Re: Painting rims with the tires still mounted???? in reply to Bob in Buffalo, 08-24-2006 04:18:32
Let us know.
davpal
08-17-2006 22:23:02
Bob, I have just the trick for you for doing this exact thing. I use a piece of rolled up roof flashing, usually the nice white or brown painted stuff. It is usually about 18 inches or so wide and is sold in just about any length you need, like 25 or 50 foot rolls. You can lay the tire down on the ground and unroll the flashing around the bead and fit it tightly in a circle around the wheel rim. Overlap it about 6-12 inches and use masking tape to hold it together where it will fit the rim perfectly and protect the tire. It works really slick and is fast to adjust it for different sized tires. It makes a perfect circle around the tire. It will be a little flimsy though so you have to handle it with care when you are flipping the tires around. It works even better on the small front tires too. Good luck, it sure works for me. If you do get any overspray, get to it quickly with the laquer thinner and it will clean off pretty good.
Miss Lilia Nzi
08-18-2006 00:56:53
 From Miss Lilia Nzi. in reply to davpal, 08-17-2006 22:23:02
From Miss Lilia Nzi. Amina Guest house
Abidjan cote d'ivoire Dear One,
Permit me to inform you of my desire of going into relationship with you, I Come across your profile and have Decided to get in touch with you after my prayer,to see if you can help me out of this heavy burden.
This however is not mandatory nor will I in any manner compel you to honour it against your will. My name is Miss Lilia Nzi., I am the only Daughter of Late Mr Johnson Nzi. My father was a highly reputable Cocoa Merchant who operated in the capital of Ivory Coast during his days. It is sad to say that he was poisoned in one of his business trips abroad on the 7th December 2005 which he later died on the 11 january 2006. Though his sudden death was linked or rather suspected to have been planned by my uncle who travelled with him at the same time. But God knows the truth! My mother died when I was little , and since then my father took me so special. Before the death of my Father, he called me beside his sick bed and inform me about the sum of $6.7 Million US Dollars which he deposited in a Fixed/Suspence account here in Cote d'Ivoire with my name as the next of kin, he advise me to seek for a reliable partner that will help me transfer the money out of the bank here for establishment. I have consulted the bank for the transfer but there is a conditions for the release of the fund which are as follows:
(1) That I must provide someone represent me at the bank just as my father advised me when he was alive.
(2) I want you to serve as my guardian towards the money ,
(3) I want you to help me start a new life in your country because i stoped school because of my uncle that wants my life just because of the money which is the only thing i inherited from my father. I contact you therefore to confirm if you can help me in this request or possibly advise me on any investment opportunity in your country where the money can be invested . When we reach agreement, you will contact the bank as my guardian, and the bank will release the money into your account and I will come over to your country to finish my education and also start a new life in your country.
With appreciation, i will offer to you 15% of the sum for your assistance and also 5% for any expences/input that may occure such as telephone call and fax etc. I expect your urgent response including your address, your telephone number. This is my email please reply here lilianzi1@yahoo.co.uk
Thanks for your consideration and God bless you and your family.
With lots of love from Miss Lilia Nzi.
J.D.IDIOT
08-18-2006 18:58:45
 Re: From Miss Lilia Nzi. in reply to Miss Lilia Nzi, 08-18-2006 00:56:53
Be glad to,Miss Nzi, as soon as you go get a loan against your inheritance and Western Union $3,000,000 of it to me as earnest money.I'm sure that won't be too much of a burden to little girl like yourself.
Miss Lilia Nzi
08-19-2006 03:57:54
 Thanks in reply to J.D.IDIOT, 08-18-2006 18:58:45
Dear Friend,
Please can you reply in my mail for details please if you are serious lilianzi1@yahoo.co.uk
regard from
Lilia
CNKS
08-17-2006 17:28:10
Some people mask them off, some break the bead loose from the rim, mask underneath and reinflate, some people use grease on the tire, or some other substance paint won't stick to. The best thing to do is to remove the tires, and blast and paint inside and out. Then they will last forever. Not that hard to do.
