Ah, that's better defined. But you did say "the best". And for that, you need to think in terms of more than $200 per gallon, perhaps significantly more, just for the color coat. I am of the opinion that the best value for the money, giving very good performance, including gasoline resistance is an automotive "economy line" acrylic urethane. The manufacturer is not that important, assuming it's one of the major paint suppliers. You should find that in the $100-$150 per gallon range. An acrylic urethane will require a hardener additive. Any of the major automotive paint suppliers will have detailed written instructions in the form of technical data sheets (also known as "P" sheets) that spell out all the additives, their mix ratios, application details and compatibility with other products in the same line. Those are generally available on-line at the manufacturer's web site. I use and am familiar with PPG's OMNI "economy" line where the acrylic urethane is referred to as MTK. DuPont will have a similar product in their NASON line. Martin Senour (NAPA) and others have a similar, competitive, line of paints but I am not familiar with their designations. The other issues are as follows: 1. Single stage or basecoat/clearcoat (bc/cc). 2. Compatibility with what's already been applied. 3. Use of clearcoat if not required by bc/cc choice. 4. Precision of color shade. I like (assuming non-metallic) a single stage paint where both the color and gloss are accomplished in a single step. Others will prefer a bc/cc two stage application where the color is first applied w/o gloss and the gloss is achieved as a separate application of a clear. No matter how you or your painter proceed, the matter of compatibility with what's already been applied exists. I have nothing to add there other than I don't know. It sounds like a crapshoot. Where decals are involved, especially the main hood decals, I much prefer the cut vinyl type of decals with a clear coat over them, even if the color is a single stage paint that doesn't require it. I just think that results in a better appearing decal that looks more like it was actually painted on. It also provides some limited physical protection to the decal. If you do use a clear coat, it should be the exact clear that is recommended by the manufacturer over the color, no matter if the color is single stage or basecoat. Plus, the other sheet metal should also be cleared so as not to provide any difference of appearance. With any automotive paint, you may or may not get a good match with an original tractor color. Generally, you can expect something called "best match possible". If you are particular about the exact shade, then some sample applications may be necessary. There can be slight differences in old tractor colors between paint manufacturers, between lines from the same manufacturer and possibly even between chemistries in the same line. The mixing tints are different and the color quality control is not as refined as in a premium modern car/truck color. Unfortunately, probably the best color match to an original tractor color will come from a dealer paint, which generally is also less costly and significantly lower in performance. Perhaps someone who has been down the JD specific Classic Green route with an automotive equivalent can provide some input here as to possible code numbers and how close the match is to dealer paint. I am not familiar with the JD colors. Assuming body work has been done on the sheet metal, a surfacer product should also be considered between the primer and color coats (sheet metal components only). That will be defined in the manufacturer's technical data sheet for the color as to what is recommended and is compatible. If a choice is available, a urethane surfacer, sometimes referred to as a "2K" product, using a hardener, would be preferable. I don't mean to make this more complicated but I don't want you or your painter to go down a path and not be satisfied with the result, even a few years down the road. The biggest problem I see for you is the existing primer. It really is a shame to put a urethane over an inferior primer. And if it isn't epoxy, I think it's inferior, to be quite blunt about it. Rod
