PPG John Deere Color Codes help
Clinton
09-07-2006 05:58:45
I have tried to do my research with searches but have came up with quite a few codes for The Green on a John Deere. I want to get the correct code for letter series A,B, G. I have seen the link to a outside website showing aprox 4 colors, Which one is correct
40249, 47910, 41374, 46180 or another? Thanks for the help.
B-maniac
09-07-2006 18:51:45
 Re: PPG John Deere Color Codes help in reply to Clinton , 09-07-2006 05:58:45
I use 43817 on the ones I do,and never a complaint. On my own 1950 "B",it matched (after polishing up)2 small areas I found that were original paint with no sun exposure and away from the heat. In my opinion,from 20' away,you won't see the small diffrerence there is in most of the "antique" green codes. If you are looking for "perfect", you will never paint your tractor. Unless you know someone who has the batch number from the factory for each month and year they were built,and can convert that to a "modern" tech paint without any "human" deviations along the way,then there is NO perfect. Compare all the actual chips you can find for "antique" green, and pick out the one that you like the best and you will be just as close as the rest of the tractors at the show or wherever. Good luck with your DEERE 2cyl.
