Farmall Rims: galvanized, zinc or paint?
Countryjent
09-08-2006 20:28:13
Woundering what is the true coating on old farmall rims? I have been restoring tractors for 15 years now and have always gone with the standard IH Silver paint for all the rims.. But I feel this is not the true coating that was used.. They seem to be a type of galvanizing.. Some have told me its just a zinc coating.. I have had some rims that have been in very good shape and they did not have paint on them.. I read an artical a couple years ago about a guy that had sent his rims in to be coated but dont remember for sure if it was galvanizing.. Keep in mind I want these tractors to be as close to the way they came out of the factory as posible.. Any help would be a big help.. Thanks
Brad_bb
09-12-2006 13:00:26
 Re: Farmall Rims: galvanized, zinc or paint? in reply to Countryjent, 09-08-2006 20:28:13
I find that it"s better you paint them only becuase that way you can bodywork them first and fill all the pits. If you plate them, you"ll still have the pits (unless you have a chromer solder and copper and sand and file them -which would cost a fortune and is not practical at all).
Dick L
09-10-2006 18:50:20
 If You Really Want True in reply to Countryjent, 09-08-2006 20:28:13
Take them and have them hot dipped galvanized.
Dick L
09-10-2006 18:58:02
 A Directory in reply to Dick L, 09-10-2006 18:50:20
To get stuff galvanized
CNKS
09-09-2006 09:01:47
Galvanized -- there is no official color, as IH requested only corrosion resistance. The original rims were really rather dull, and difficult to duplicate with paint. Aluminum and "silver" paints are usually too bright. I use a version of GM rally wheel paint, sort of a siver gray color, PPG 8568. Not saying it is "correct". I really doubt if galvanizing will increase the value of your tractor, but if you want to have it done, go ahead. If you want the whole tractor to be "original" you also have to use the cheap alkyd enamel, and get the correct color. It is my belief that the original IH 50/1102b/201 red colors plus the 1961-up 2150 really do not exist anymore, as the manufacturers have changed, and the colors they are using did not come from IH (CIH currently uses Valspar), but were someones interpretation of what the color should be. The paint from the major manufacturers, including PPG, DuPont, and Sherwin Williams/Martin Senour/NAPA all have their own versions, along with the cheaper alkyd enamel furnished by Van Sickle, TSC, etc. I have mine tinted according to what I think it should be, which likely results in the wrong color. You just have to do the best you can.
Nebraska Kirk
09-09-2006 06:12:38
The Farmall letter series rims were galvanized.
