sandblasting with walnut shell
jd 2020
09-18-2006 09:18:39
I was in a harbor freight tools store a few days ago. I noticed they sell walnut shell 24 grit soft abrasive. On the box it reads "ideal for cleaning engines and transmissions" I was wondering I if could sandblast my tractor with this stuff without damaging the seals. or just use paint striper and elbow grease. The tractor is in excellent condition but it needs to be painted
bill
Brad_bb
09-19-2006 11:39:33
 Re: sandblasting with walnut shell in reply to jd 2020, 09-18-2006 09:18:39
third party image
I"ve used Walnut shells in my blast cabinet. Same pressure to shoot. I was using it to blast aluminum parts like bellhousing and timing covers (Pontiac parts). In the end I found it to be too slow and didn"t give the finish I wanted. I ended up using glass bead. On die cast zinc parts, the shells would be good so as not to damage the original surface finish like on an alternator housing.
I"d advise masking with duct tape and sand blasting your tractor frame. Walnut shells will be too mild and will not remove any rust. I had mine sand blasted.
In the attached pic you can see that I cut a cover our of wood to cover the clutch cavity and used a layer of plastic sheeting to act as a gasket and bolted it in place at each hole location. I masked off a few other areas that I didn"t want sand intruding. The steering wheel is masked off as well as the gearshift knob.
RedFord
09-18-2006 11:14:25
Walnut shells seem soft but they are actually quite aggressive. While I have nothing against walnut shells, they are nearly as hard on seals and machined surfaces as sand, grit, etc. Why not mask the critical areas with duct and/or electrical tape, blast easy around the masked areas, then manually clean just the areas that were masked.
dr.sportster
09-18-2006 14:33:04
 Re: sandblasting with walnut shell in reply to RedFord, 09-18-2006 11:14:25
Do they take the same air pressure to blast as sand?[Not trying to hijack your thread but was curious]
