Tim, I think much of that other thread got lost forever due to the server problems Kim has been having recently with this site. Yes I used POR15 under it. See my post below, titled "KCSUPERMMAN..." for a discussion of my use of the POR and epoxy as a binder coat with the topcoat color. Also pics of pre-POR prep and post-POR are in that thread. The post-color pic is in my thread below titled "AC PO Nuts". Here's the post-epoxy pic (a single coat): ![third party image](http://img243.imageshack.us/img243/6396/afterepoxydj7.th.jpg)
Day 2 with the POR application was the tight part, schedule wise. I put the housing in the shop after prep the day before so I could start fairly early the next morning with the POR, not having to deal with drying the dew off the housing. The temp was about 75F and the POR took about 3 hrs to get to that "tacky" point where the second coat could be applied. Another 3 hrs before applying the epoxy. The color went on the next day just before lunch so it was cured enough by late in the day to not be affected by the heavy dew that evening. I could have put it back inside but didn't need to bother. I'm sensitive to painting color late in the day and having dew turn it all cloudy by next morning - I've been burned twice that way in the past. Today, I put POR on the first stage augers and the discharge chute. The temp was in the high 60'sF and not as humid as before. It needed 4 hrs between coats. I wound up applying the epoxy coat between 5 and 6 pm. So I needed about 9 hrs elapsed time from beginning the first coat of POR to applying the epoxy binder. This is the first time I have done this so I am not sure how it's all going to turn out. But I'm cautiously optimistic. I am mostly curious as to how well the POR is going to hold up on the impellers and on the interior of the discharge chute where it's going to take the worst beating. It seems to be brutally tough stuff - as tough as it gets, I'm told. I expect the color and epoxy will wear off fairly quickly in the discharge chute. Time will tell with the POR. I really doubt it will hold up very long to such abuse in those areas, but then again the blower is not my primary means of handling snow. I haven't used it much at all in recent years so it's not likely to get heavily used. I take it your POR is now fully cured and you want to topcoat it. I think you said you had some of POR's "etch primer". That should do the trick and be in full accordance with their written instructions, although it was not clear to me if scuffing was not also needed in that situation. I have found their instructions to be a little less than I would like and even conflicting in a couple of instances. Rod
