Gas caps,rad caps,How would you....
Dan
04-16-2002 15:53:43
repair something like that. I have a dented one,don't think I can take it apart so could I just go ahead and put some filler or is there a bodyman out there with some suggestions. As you may gather, I'm new at this. Thanks.
Steven@nd
04-25-2002 11:56:15
 Re: Gas caps,rad caps,How would you.... in reply to Dan, 04-16-2002 15:53:43
If you repair the old cap, be sure not to plug the vent holes or you could ruin your gas tank.
Steven
car
04-17-2002 16:43:31
Sure you can.Grind out the dents,fill with bodyfiller,sand down to a smooth surface with fine sandpaper,shoot with high build primer,fine sand if necessary,repeat primer and should be ready for paint.
car
04-17-2002 16:42:56
car
04-17-2002 16:41:23
Jerry B
04-17-2002 08:28:02
Frank is right. Buying a new cap that has the new gasket, unworn edges, and ready for paint saves a lot of time and material.
Jerry B
04-17-2002 08:27:20
Frank
04-16-2002 17:09:54
If new ones are still available, I wouldn't go to a lot of trouble trying to fix it. They can't be very expensive.
My 2 cents
Frank
