Paint on rubber tires
Jamason
09-24-2006 17:41:02
This is kind of a stupid ?, but how do you get dried paint off rubber tires. I have tried alot of stuff and it will not even began to come. what should I use. Thanks
horterrestoration
10-08-2006 20:28:31
 Re: Paint on rubber tires in reply to Jamason, 09-24-2006 17:41:02
Flat black spray paint will cover it if you wish not to use chemicals to remove the overspray...
Ron Grother
10-05-2006 02:34:32
miller tire sells a tire paint it mixes with water. it great
souNdguy
09-26-2006 10:21:25
Laq thinner, carb cleaner spray, brake cleaner spray... mind you.. this is a tad rough on the rubber.
400 sand paper will scuff it off pretty well too.
Old is right.. many of us coat the tire with something.. like silicon rub, tire soap.. etc...
Soundguy
Red Ford
09-25-2006 08:31:34
Stripper is hard on rubber, but if you have a lot of catalyzed paint on the tires you may have no other choice. I normally scrape off what I can, then use a medium-wet lacquer thinner rag to remove the rest.
old
09-24-2006 21:17:03
Did you do this or did you buy it that way. I use vasoline on tires before I paint so that you can just wipe off the paint. Now if you didn't do that then you will need to use something like carb cleaner etc to get the paint off and the longer its there the harder it is to get off. BTDT and learned the hard way
B-maniac
09-24-2006 20:13:52
Sand blaster or aircraft stripper both work perfect.
KRUSS
09-29-2006 10:13:27
 Re: Paint on rubber tires in reply to B-maniac, 09-24-2006 20:13:52
Is there a suitable black paint to paint over the overspray. I have a bad case of red paint on tires on a tractor I bought. Nothing I've tried yet has worked very well.
