Re: exhaust hole in hood
Brad_bb
10-05-2006 06:53:24
I"m not clear whether you are just trying to close up extra holes someone cut or remake an original hole. Either way...
You don"t need anything fancy to make a patch piece. Trace out the hole and make a nice tight fitting patch piece. If the hole is bent up and not flush all the way around, use a body hammer and dolly to straighten it out before making the patch. Clean up any edges with a file. If you need a little curvature on the patch it"s very easy to find something with a cylinder shape and just press it around there by hand. I"ve uses my CO2 tank before or other tube shapes depending on the approx radius I needed. The carefully tack the patch in place with a MIG making sure the position and height relative to the hood sheetmetal is correct. I then prefer to TIG weld small sections at a time until it"s fully welded. Tig welds and softer and can be hammered on if need be afterwards. Mig welds are too hard and won"t stretch. Then you can use sanding disk to clean up the weld -I like a mini pneumatic angle grinder with 3m 50 grit roloc sanding disks. Then you can go back with the hammer and dolly and adjust the patch as need be to get it even to just below the correct level. Then you must metal prep the area to neutralize any of the oxidation that welding begins. Then you are ready for filler/body work.
