Rusted Fenders
Dubl J
10-15-2006 15:36:56
The fenders on a truck I recently bought are rusted out on the bottom sides of it. At some point in the trucks life someone tried to fill in the rust spots with bon-dough and its starting to fall out. I know I need to get rid of all the rust and go down to bare metal, but what do I do then. DO I try and weld in new metal or does fiberglassing work for this. Its on a IH R-190 truck. I plan to re-store the truck but I am in the Where Do I Start Phase. JJ
beperson83
02-13-2007 09:30:04
 Re: Rusted Fenders in reply to Dubl J, 10-15-2006 15:36:56
I wouldnt recommend fiberglass. It might work for you, but it didnt really work for me. I would also go with the cardboard template and then transfer that to sheet metal and weld it in. Be carefull because the metal will warp really easy. I had some warping problems when I welded some onto my tractor when I restored it, but it turned out ok.
rustyj14
10-20-2006 13:19:26
Before you do any cutting or banging or other things, take some thin cardboard, like comes in a new, man's shirt. use a pencil and draw around the part you are going to replace, to make a pattern. Make it bigger than the part. then after cutting it out to the reasonable shape of the rusted out area, leaving about an inch of cardboard all around, lay it up against the rusted area, and cut slits in all areas that have to be bent to shape. If you use this method, its lots easier to bend and cut the cardboard, than to wrestle with a piece of tin! When all is formed to reasonable shape, then lay the pattern onto a sheet of auto body tin, (If my memory serves me right, i think its 22 guage) and draw the outline, and then make your cuts, like in the cardboard, form it to shape, and weld it into the fender, etc. Weld up all cuts, and do the plastic filler work. Note: you must have all welds and crevices really clean to bare metal to make the patch last. Any holes left in your welds, or attachment areas, will let moisture into the patch area, and cause premature rust! I usually brazed the patches on, but you can use steel rod, too.
Note: Fibreglass or body plastic, without metal welded fully in place, will not last very long, unless you live where it never rains! Rivets do that too.
Southpaw
10-16-2006 08:42:39
Depends on the size of the holes once you've ground and cut out the rust. From the way you've described the previous repair it sounds like the holes would be to extensive for a fiberglass repair to stand up long.
