painting bolt heads
daniel h.
10-17-2006 16:58:49
What is the best way to get paint to stick to zinc plated bolts?
RobertTX
10-26-2006 13:29:45
 Re: painting bolt heads in reply to daniel h., 10-17-2006 16:58:49
Pickle them in acid.
rustyj14
10-24-2006 09:54:00
Prime them with zinc chromate primer first--when that is dry, you can prime with laquer primer, but not necessary.
Dean Glover
10-18-2006 18:43:51
I have a couple of pieces of board with many various size holes drilled in them and stick the bolts in them, sand blast them and paint them while in the same boards. I use these over and over again. Dean
Dan (wi)
10-18-2006 18:00:34
have blasted them in a cainet,prior to cabinet used wire wheel,you just need to scruff them up a bit,then I shove them in a sheet of cardboard,hang them & paint them.
