52 ford 8n delstar paint
dale goeking
10-21-2006 15:20:37
were do i find delstar ppg 31657 paint code to nacth dupont waht numbers and what paint for the hood gray what do you guys you use and numbers
Rod (NH)
10-21-2006 18:03:16
 Re: 52 ford 8n delstar paint in reply to dale goeking, 10-21-2006 15:20:37
Dale,
If you are looking for a DuPont paint equal to PPG's Delstar acrylic enamel, it would be Centari. It's available in three different field mixes. You have to decide which one you want before you purchase because they each use different additives that you'll need to buy when you get the color. The actual can of color is the same for all three. The choices are 1) Centari w/Ultra Performance Pak (acrylic urethane), 2) Centari w/793S (acrylic enamel w/hardener) and 3) Centari w/Ultra 1K Pac (acrylic enamel w/o hardener). As far as the number goes, I take it the 31657 is a PPG number and you are looking for an equal color number from DuPont? You'd best get that from a DuPont jobber to be assured of the best and latest cross-reference information. However, be sure that the 31657 in PPG is the exact color shade you want. That number does not show up in the PPG tractor listing that I have for Ford. There are several grays noted but not that specific one. Here's a DuPont tractor color listing that might help you out also. Lots of different Ford grays
third party image Rod
