paint quality BPS versus Valspar
djw
11-01-2006 04:55:05
I know from past posts that the Tractor supply paint [BPS] is low quality, But I see they now are carrying a Valspar line of paint. Doe's anyone have any experiance with this paint? I seem to recall the valspar name from years ago. It is about $20 more a gallon than the BPS. Thanks Dave
djw
11-01-2006 13:30:58
 Re: paint quality BPS versus Valspar in reply to djw, 11-01-2006 04:55:05
I just did a google search for Valspar paint, guess what , they make the BPS brand and just changed the label to Valspar. Now they can charge $20 more per gallon for the same paint! Gotta love marketing. Dave
CNKS
11-01-2006 18:29:18
 Re: paint quality BPS versus Valspar in reply to djw, 11-01-2006 13:30:58
With the "off" brands (yes I know Valspar makes acrylic enamel and urethanes), look and see what the paint is, rather than the brand, which can be meaningless. Alkyd enamel is the lowest grade, acrylic modified alkyd enamel is a step up and better than straight alkyd as it has UV inhibitos to retard fading, acrylic enamel will be better than acrylic modified alkyd, it will last longer; urethane is the best. PPG/DuPont/Sherwin Williams (SW is the same as Martin Senour and the NAPA brand, I believe) are the name brands and are higher quality than Valspar. That does not mean you shouldn't use Valspar, as long as it is something other than straight alkyd enamel. But, quality paint costs money, it is worth it in the long run.
960
11-01-2006 14:08:18
Valspar makes many levels of paint quality wise including OEM paint for several well known Ag. manufacturers. The BPS is pretty sad.
souNdguy
11-01-2006 12:26:13
BPS is the economy stuff.. alkyd. What's the valspar? acrillic?
Soundguy
B-maniac
11-01-2006 17:28:00
 Re: paint quality BPS versus Valspar in reply to souNdguy, 11-01-2006 12:26:13
My opinion is that it is the exact same stuff,re-named because the sales of BPS was falling off (for obvious reasons) so now we will put our "real" name on it and people are bound to believe it's better and sales will pick up and the cycle will start (and end) all over again. It's all about price,not quallity. They will sell a lot of paint before they have to "change" again.
souNdguy
11-01-2006 17:43:35
 Re: paint quality BPS versus Valspar in reply to B-maniac, 11-01-2006 17:28:00
A quick check on the can should determine it's chemical makeup. I sure wouldn't want to pay 46$ per gallon for alkyd enamil that was availbale at 26$.
Soundguy
