Hi Greg, I'll chime in and agree with the other two - which is not unusual. Before you buy into the Rustoleum primer/JD alkyd topcoat, consider the following (my opinions only): 1. It may work for him but it is definitely not in accordance with the Rustoleum written instructions, especially if he is putting that rusty metal primer over anything but pure rust. Here's what Rustoleum has to say about it: Can I use Rusty Metal Primer and Clean Metal Primer on my car? Stops Rust Auto Primer is formulated for use with automotive touch up paints. Rusty Metal and Clean Metal Primers should only be used if top coated with Rust-Oleum paint. Can I use Rusty Metal Primer on clean metal? No. The fish oil that is in the primer needs to penetrate into rust to seal out air and moisture. If there is no rust, the oil will rise to the surface making adhesion of the finish coat difficult. And I doubt that it's in accordance with any JD label instructions either. 2. It may look great for a while, but see if you can see one that has been in the sun for a couple of years. That means in the sun on a regular, if not full time, basis. Not garaged and taken out only once or twice a year for shows. Alkyd enamels are notorious faders and haven't been used on cars in many, many years. They are 1930's technology. A primer (no pun intended) on paint chemistry is here. 3. Absent whatever premium cost is associated with the JD label itself, the combination you mentioned is about as cheap as it gets for paint. 4. If he says automotive paints or primers are not good, he simply doesn't know what good is. He should try selling his combo idea to Ford or GM. If he's correct, they could save enough billions to get them out of the hole they are in. 5. I wouldn't use such a combination in general myself because I usually expect better performance than I think that combo provides. I do however, accept the fact that if it doesn't self-destruct because of any incompatibilities (note fish oil and adhesion issue above), it represents an inexpensive alternative for simply protecting the metal. If that's your goal, fine, go for it. Just be aware that there are better, although more expensive, alternatives available. Neither GM, nor Ford, nor JD nor IH make their own paint. They buy it from paint companies. JD and IH likely get it from a company that deals a lot in private label paints. Valspar is one such paint company. GM and Ford will purchase from a big, well known company that has global reach and the resources to produce the custom color matches and performance they demand on a large scale. PPG and DuPont come to mind in particular and are key suppliers to automotive OEM and refinish industries along with other industrial customers. But it's really the more modern chemistries rather than brand that accounts for better performance (and cost). PS: don't worry about repeating a question. It's done all the time. Some of us may get tired of it but if we didn't want to respond, we wouldn't bother. Rod
