paint shade
TomPW
12-17-2006 13:44:35
I am restoring a 1952 Farmall Super AV. What is the correct pint? I have access to "International Red" and "Farmall Red".
What is the difference and which one is the correct one?
CNKS
12-17-2006 14:46:20
 Re: paint shade in reply to TomPW, 12-17-2006 13:44:35
Same answer I gave on the Farmall board -- what the paint manufacturer calls the paint means nothing. IH used the term "Harvester Red". The correct code is 1102b. I'm not sure it can still be mixed, and it is no longer available from Case-Ih. The cheapest way to go, assuming you don't have the proper protective equipment for the modern paints is to get IH 2150 from your Case-IH dealer, and use it without hardener. It will be much better paint than the tractor store stuff (if it is on this site, same thing) that you are considering.
