Massey Fender
Kirk in kansas,
12-29-2006 16:24:17
I have this 97 massey , and it has a creased rear fender where this roof fell in on it, and i wanted to get it home, and start in on it,
How do i get the crease out of the top of it? it goes all the way across top,
and it,s touching right rear tire,
do I just jack it up, and gently tap it out with a body buck of the right shape,
Need help,
K,C,
glennster
01-03-2007 05:52:47
 Re: Massey Fender in reply to Kirk in kansas,, 12-29-2006 16:24:17
you can either jack the fender back into place as it sits and work the dent out with a hammer and dolley, or remove the fender and do it on bench. i would put some wood blocks against the fender if you are going to use a jack to spread the force out to a wider area so you dont pucker up the area where the jack pushes.
