2670 door?
Kirk in kansas,
12-31-2006 06:18:07
my left door on my 2670 is tweaked,
it only goes to the edge of left front shroud, and then rub,s the metal and scraped the paint off, and shut,s hard, striker need,s adjusted,
glennster
01-03-2007 05:55:59
 Re: 2670 door? in reply to Kirk in kansas,, 12-31-2006 06:18:07
if the door dropped and is rubbing and did NOT get struck by something, your hinge pins are probably worn out. open the door and gently lift the door and observe the hinges for movement. you may be able to install pins and bushings if they are available, or you may need replacement hinges. this is a real common problem on gm pickups and suvs.
