PPG Paint Prep
scotty
01-02-2007 08:17:16
A few months ago I painted my 49 Super A with an enamel paint. The results were good but Im thinking about spraying all the sheet metal with a better paint. What would be involved in respraying with PPG urethane other than standard cleaning of all parts ? I have not used any wax or other cleaners on this sheetmetal since I installed it back onto the tractor.
Any thoughts and suggestions appreciated.
scotty
B-maniac
01-02-2007 19:23:47
 Re: PPG Paint Prep in reply to scotty, 01-02-2007 08:17:16
You say the results were good so I'm assuming you are happy with the looks but want the longevity of the urethane?? If it looks good , I would leave it alone until such time that it ages to a point that it doesn't look good , then paint it over. Unless you used a catylist in the enamel , I would give it one good summer in the sun anyway , before painting it with urethane. Assuming you don't need to "fix" anything , I would just sand it with 600 wet and scotchbrite (in the hard to get places) spray a coat of epoxy primer (catylized and non-sanding) and then give it one day cure before painting. Make sure your epoxy and top-coat and catylists are from same brand lines. LOL
scotty
01-03-2007 14:30:31
 Re: PPG Paint Prep in reply to B-maniac, 01-02-2007 19:23:47
B-maniac, Thanks for your reply and suggestions !
scotty
